NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
roundHeadedkid
Can we use the WCDMA measurement suite with 3rd party test equipment
I have 3rd partry test equipment (R&S) that can do arbitary waveform generation, I was wondering if there is anyway to utilize the WCDMA measurement suite (or any LabVIEW software / toolkits) to generate and analyze WCDMA signals (EVM, ACPR, Frequency Accuracy, etc)
Thanks!
Active Participant
ThiCop
Re: Can we use the WCDMA measurement suite with 3rd party test equipment
[ Edited ]
Hello roundheadedkid
I see that this question has remained unanswered for quite some time.
Is this issue still open?
One thing that could be very interesting is knowing how you're currently communicating from LabVIEW with the arbitrary waveform generator.
Several Toolkits (eg. Modulation Toolkit) have VI's that you can directly use.
Have you tried the evaluation version of these toolkits?
Kind Regards,
Thierry C - Platinum Applications Engineer - NI Belgium
CLD
If someone helped you, let them know. Mark as solved and/or give a kudo. :smileywink:
Member
roundHeadedkid
Hi Thierry,
We are communicationg via GPIB as of now. Can we use the Modulation Toolkit to make EVM measurements ? Can we push CDMA waveoforms through GPIB?
Thanks!
Active Participant
ThiCop
Can you send me information about the exact device you're using?
If this is possible, I would also be interested in seeing how you currently are doing the communication in LabVIEW.
This would maybe even allow me to optimize your code (if needed).
Kind Regards,
CLD
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
