05-05-2017 02:33 AM
Yes, phase offset is not consistent, on every run it minimizes, like for 1Ghz I was 400ps, but for 1.5 It was below 75ps.
I want to know how to add RF interpolation delay property and where in generation part for adding it control on run time.
05-05-2017 07:27 AM
Use the interpolation delay attribute that I linked to in my first post. Only set it for one of your VSTs. Positive values add delay, negative values subtract delay.
05-05-2017 07:43 AM
kindly share the info for syncronization with 5644 ref clock instead of PXI clock. I want to know how it will be accomplished as currenlty I am using PXI clock. In comment, It was mentioned that do not use on board Ref Clock.But how to do synchronization with 5644R ref clock?
05-05-2017 03:03 PM
Synchronization will not be affected by which ref clock source is used as long as the clocks are the same. Frequency accuracy may be affected, but the difference between PXI clock and ref clock sharing is very small. If you want to hit the 5644's specs, then share the ref clock.
To do that, connect device 1 ref clock out to device 2 ref clock in. Set device 1's clock source attribute to OnboardClock and export the ref clock (see below). Set device 2's clock source attribute to ref in. That should be it.
