NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member vir
Member
vir
A very accurate frequency demodulator
I am working on a biomedical engineering research project. It involves investigating the possible techniques of measuring mean light pathways variations of the light propagating through a vascular tissue.
One of the theoretically predicted ways of conducting such a measurement requires a very accurate frequency demodulator.
The predicted signal frequency modulation ranges are as following:
- f = 500 MHz, Δf = 5 μHz
- f = 1 GHz, Δf = 10 μHz
- f = 10 GHz, Δf = 100 μHz
- … (and so on – the relation is linear)
f is the base harmonic signal frequency, Δf is the expected frequency modulation range (μ - micro).
I have zero experience in both high frequency and FM techniques.
Can you advise please if it is at all possible, what devices/techniques might be used to demodulate the described above signal.
Thank you,
Victor.
Member
Ben.h
Re: A very accurate frequency demodulator
Hi Victor
I think the answer to your question is dependant on budget, time and what equipment you already have. I think it would be benficial for you to call NI and speak to Field Sales Engineer.
The telephone number for the NI UK branch is
01635 523 545
Kind Regards
Ben Hartrick
NIUK Tech Support
Active Participant
Henrik_Volkers
Might be a bit late :smileyhappy:, but how about interferometrie with the frequency of light (THz)?
Greetings from Germany
Henrik
LV since v3.1
Member vir
Member
vir
Henrik, thank you for the advice - good ideas are never too late.
I came to the same conclusion: laser light + interferometer + beating should do the job.
Victor.
Active Participant
Henrik_Volkers
We use homodyne laser interferometer here. That allow us to measure changes in distances in fractions of the laser wavelength.
One good (major) adress is Polytec, if you don't want to mess around with the optics by yourself.
Henrik
LV since v3.1
Active Participant
Henrik_Volkers
Short correction: replace homodyne with heterodyne... :smileyhappy:
and here is the link to Polytec
http://www.polytec.com
Henrik
LV since v3.1
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
