02-20-2008 12:29 PM
niRFSA Read IQ (Complex Cluster 1Rec 1Chan).vi<ERR>The frequency tuning PLL is not locked.
Status Code: -233532
Can anyone help solving this problem?
Thank you.
Chen
02-20-2008 04:47 PM
02-20-2008 09:06 PM
02-20-2008 09:22 PM
Hi, Andy,
We use the test panel of 5660 in MAX to test our GFSK signal, the same error occurs. THe error informatino is:
Error -1074118635 occurred at niRFSA Read Power Spectrum (Cluster).vi
Possible reason(s):
Device: RFSA
Thank you,
Chen
02-21-2008 02:55 PM
02-22-2008 04:24 PM
Andy,
Our digitizer is 5142. We are using Labview 8.2. Therefore we cannot open the VI you attached in your post.
The scope workes well. We had deveopled several ATE using the scope, and run these ATE every day.
Thank you,
Chen
02-25-2008 02:21 PM
02-25-2008 05:41 PM
Hi, Andy
THe results of runing the VI are attached.
We don't configure the clk of the scope in SW.
Thank you,
Chen
02-25-2008 05:48 PM
02-26-2008 01:25 PM
