As per datasheet the phase noise of 5645R Receiver is -112dBc/Hz @ 1GHz at 10KHz offset.For our DUT, we have to measure phase noise of -138dBc/Hz at 169MHz @ 1MHz offset. Is it possible?
Also is it possible to generate 2GFSK using 5645R?
Is it possible to generate dual tone CW signal from 5645R Transmitter?
