Hi to everyone:
I am new working in the cRIO9074 and I used LabVIEW2016 and I tried to programing in the LabVIEW-FPGA. I use the module NI 9401 for the DIO.
I used examples files and I generate two loops, one for the Triangle waveform and other one for the Sinusoidal waveform (3 sines waveforms with a phase shifter of 120 degrees). I sending these signals to an osciloscope and I can see the correct waveforms, but here starts my problems:
1. How I can define the frequency of the triangle waveform and the sinusoidal? the example appears the Carrier frequency depends of the Ticks, so if I understood well, if I need a carrier frequency equal to 1KHz, I have to put 40000 ticks (40e6/N of ticks = carrier frequency)... that is correct?
2. The same problem for obtain sinusoidal waveforms with 50Hz.
3. I compare the triangle waveform and the sinusoidal waveform and send to the NI 9401, but I tryiend to measure by an osciloscope the DIO in the module but I don't obtain any signal... is a problem of the program?
4. I will need to create the phase shifter in the modulation signals, I used the example send by BMac (Many thanks!):
http://forums.ni.com/t5/Power-Electronics-Development/Phase-Shifted-Carrier-Signals-For-FCM-applicat...
but the sistem send me a error and was imposible to compile... there are other option?
I attached my program files... many thanks in advance
Ricardo
