Power Electronics Development Center
How do I install the Multisim co-simulation plug-in for LabVIEW 2014?
I recommend you install Multisim 14.0.1 since it has native support for LabVIEW 2015 and LabVIEW 2014 as well as the fix to the bug reported above. (When running LabVIEW-Multisim co-simulation, Multisim may crash if the Multisim design file is copied to a new location and the VI is updated to reference that new location.)
Here are links to the Multisim 14.0.1 installers:
NI Circuit Design Suite Power Professional 14.0.1 - Full and Base Editions
NI Circuit Design Suite Educational Edition 14.0.1
When you install, be sure to choose to install the NI LabVIEW Multisim Co-Simulation Plug-in.
If you want to install co-simulation support for LabVIEW 2016, install Multisim 14.0.1 and then follow these instructions.
1. Install 7-Zip if it is not already installed. Download this zip file (Multisim Design.zip) and place it in the folder below. Then right-click and select 7-Zip>Extract Here.
C:\Program Files (x86)\National Instruments\LabVIEW 2016\vi.lib\Simulation\EMI\Plugins
Then the ..\Multsim Design folder should appear as shown below.
2. Download this zip file (help.zip) and place it in the folder below. Then right-click and select 7-Zip>Extract Here.
C:\Program Files (x86)\National Instruments\LabVIEW 2016\help
Then the ..\help folder should include the files "msmcosim.chm" and "msmcosim.txt" as shown below.
3. Then restart LabVIEW.
Message 11 of 15
(4,643 Views)
To test your installation, I recommend you try running this LabVIEW FPGA/Multisim co-simulation tutorial project. It is a good starting point for developing your own custom power converter circuit model and control algorithms.
ftp://ftp.ni.com/evaluation/powerdev/training/CoSimulationTutorial2015.zip
Here is a screenshot.
Message 12 of 15
(4,643 Views)
thank you it installed properly through your instruction
Message 13 of 15
(4,643 Views)
How to install the Multisim co simulation plugin for 2020 labview
Message 14 of 15
(1,943 Views)
Could you please send me the link again? I am not able to download the files from the given links
Message 15 of 15
(1,681 Views)
