Past NIWeek Sessions
TS9243: Capturing ATE Requirements With NI Requirements Gateway
Speaker: Juergen Dodek (Engineer, MTU-Friedrichshafen GmbH)
Explore advanced requirements tracing and validation with Requirements Gateway. See how MTU-Friedrichshafen GmbH, a subsidiary of Rolls-Royce, used Requirements Gateway in its PXI- and TestStand-based functional test systems. Learn how to verify claimed limits in the test specification against implemented limits in a TestStand sequence file. Discover how a closed trace path loop is constructed by analyzing wiring documents.
Comments
Active Participant j_dodek
I am inviting you to my session. You will get an insight into NI-Teststand and NI-Requirements Gateway
See what you can do with this tools
Juergen
--Signature--
NIWeek 2016
Session:TS9243-Capturing-ATE-Requirements-With-NI-Requirements-Gateway
Feedback or kudos are welcome
