03-12-2015 01:58 AM
chassis: NI PXIe-1078
ini file to import in MAX
see attachement
thx
Solved! Go to Solution.
03-25-2015 05:22 AM
Dear kdCMC,
I can't see the purpose of this. Which drawing connection diagram are you referring to?
Best regards
03-25-2015 05:35 AM
Hey,
i want to draw the entire connection diagram of the test system between the NI PXI cards and our pinbed.
Then, it's nice to have the pinout diagram of the PXI card.
If You don't have the PXI setup, You need to enter it as simulated in MAX to have, for most of the cards, an easy reference to the pinout diagram, which i use in MS xls to draw connections. otherwise, You need to search for it in the NI website, which is time consuming.
regards,
Koen.
p.s.: i did it for a PXI mux with success. at first, i wanted to enter in MAX simulation my entire PXI setup, inclusive chassis....
03-25-2015 11:19 AM
Dear Koen,
Sorry if I don't see it, but there isn't that much information about the chassis in MAX.
The ini files will be generated when the system detects the chassis. In case of a third party or custom alt. one have the option to add those ini-files.
regards
/Lars
03-25-2015 11:28 AM
Hello again,
ok, thx. but say You want to write already your code for the NI hw that will come in, or you want to support your setup which is running elsewhere, then, don't you need the ini file for full simulation mode?
regards,
Koen.
03-26-2015 02:31 AM
Hi again Koen,
Unfortunately you can't simulate a full PXI system, hence we don't have the option to simulate a PXI controller unit. The simulation you can do is to setup the cards you intend to use in you.
regards
Lars
