we want to use the PXI-7813R 3M Gate Digital RIO (160 DIO) card to generate PWM signals, test I2C communication and use it for SPI testing/communication.
Perhaps also some conventional I/O testing...
They've told us that on the site www.ni.com/ipnet we can find IP to do this.
My question: do we need additional software tooling to use/program this FPGA? Or is just downloading some libraries via VIPM and "using" some vi's sufficient ?
You will need to have LabVIEW, LabVIEW FPGA and the Xilinx tools which will be installed with the FPGA module.
You can find IP where you mentioned for SPI and I2C the generation of PWM you can find in LabVIEW Example Finder under Help in the toolbar. The general I/O testing will need more info to describe where to find info how to do it.
Best Regards Jonas Mäki Systems Developer Novator Solutions
