07-10-2017 02:08 PM
I am using the niRFSG Allocate Arb waveform.vi to bring in a 6G waveform file.
I am getting errors such as: total memory of all waveforms exceeds the allocated amount of memory on the FPGA.
Is there a way to adjust the FPGA memory on the PXI 5646 to accommodate the 6G waveform data file?
Here is a setup
07-11-2017 09:19 AM
Hi cosburn,
I don't think you are breaking up the waveform into enough smaller chunks to fit into memory. You can check the total size of the arb memory on the PXIe-5646 using the property Arb:Memory Size (http://zone.ni.com/reference/en-XX/help/371025N-01/rfsgproperties/cnirfsg/). Make sure that the waveform you are trying to allocate to memory is smaller than this size as discussed in this document: http://zone.ni.com/reference/en-XX/help/371025P-01/rfsg/streaming_waveform_data/.
07-17-2017 09:55 PM
Hi Luke,
I have not considered breaking up the size of the waveform. That makes good sense considering the RAM is 512K X 2 and is probably filling up while leaving the remainder unaccounted.
Your response provides me with some great direction to fix this issue.
thanks
Cosburn
