I would like to set up 2 systems on a single PXI chassis/controller.
both systems will monitor 4 channels. System 1 will use channels 1-4 and system 2 will use 5-8. Since these systems are to be completely independent of each other, I plan to make two separate LabVIEW executables.
Will both executables be able to simultaneously monitor the DAQmx config? Are there any pitfalls I need to watch out for?
I am using LV 8.5 and the latest DAQmx. I don't have hardware available for me to try this, hence I am posting.
Thanks!
Charlie
