NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
PXI
Reply
Member
leoking99
pxi synchronization PXI6289 with PXI-8464
I am fairly new to Labview and trying to develop my first application that uses triggering across multiple devices.I will try to explain in detail what I am trying to do, and I could really use some help trying to figure it out.
I use labview 8.5.1 and max-4.5.
I am trying to acquire:
1. a waveform signal using PXI-6289 and SCB68
2. CAN bus frame using PXI-8464.
I would like to start the tasks at exactly the same time and sample using the same hardware sample clock. So Ineed to do synchronization.
I have studied the example “CAN Frame API Input DAQmx Input1.vi”,but it for PCI card not PXI card.
Then I wrote a VI “Sync CAN-frame API with DAQ2.vi”, chane the string “RTSI” to “PXI_TRIG”.
But PXI-6289 is on slot 4 and PXI-8464 is on slot 12, so I configured PXI_TRIG0 and PXI_TRIG7  to "away form slot 1"in MAX.
I want to connect PXI-6289’10MHz RefClock to pxi_trigger7, and ai\start trigger to pxi_trigger0.
But the error 89126 occurred.
I really confused about it, what’s wrong with my VI? What should I do to get rid of the error and get my VI working?
Any advice and help would be highly appreciated.
Member
leoking99
回复: pxi synchronization PXI6289 with PXI-8464
After more than s years study, I can solve this problem all by ,myself. I figure out the difference between RTSI7 and PXI-star and th ecommon use of RTSI0-7.So end of this question
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
