11-16-2006 04:40 AM
11-16-2006 05:00 AM
11-16-2006 10:12 AM
11-17-2006 01:58 PM
If your second AWG was also a National Instruments AWG, you could do this. You would include the second NI AWG in your TClk synchronization (so it shared not just a commone Refernce clock, but also a common trigger clock (TClk)). However, this second NI AWG would not start at the same time as all the other devices in the system. It would start with it's own Start Trigger (which could be immediate, software, digital edge, etc.), but the start trigger would be delayed so the AWG would start on the next TClk edge. If the "trigger" being exported by the second AWG was a marker event, it would alway come out at a particular sample, which has a fixed relationship with the TClk edge that the AWG started on. This "trigger" (event) would then be received by the other devices in the system and you HSDIO device(s) would also start with a fixed delay between the "trigger."
The fundamental problem is that your external AWG, while sharing a reference clock, is not starting, nor exporting it's trigger, synchronous to the trigger clock (TClk) that is starting the other devices.
Neil Feiereisel
Software Engineer
Modular Instruments
11-21-2006 10:25 AM
11-22-2006 08:39 AM
11-28-2006 03:22 PM
