06-18-2012 03:02 PM
A question regarding the PXI-8431/8 serial port card: Is it possible to directly control the TX (transmit) & read the state of the RX (receive) lines? I need to implement a serial communication scheme using separate data and clock similar to SPI using differential line drivers.
Looking at the RS-485 Transceiver Control.vi example, I see that it is possible to control the state of the serial port control signals, CTS, DCD, DSR, DTR, RI, and RTS.
Solved! Go to Solution.
06-19-2012 09:27 AM
Hello wantacobra,
You will not be able to directly control the TX & RX lines because the PXI-8431 is specifically designed for RS-485/422 protocol. The transmit and receive lines will always expect a serial packet. Yes, you can control the serial port control signals, but not the TX & RX lines directly. It would probably be better to get a chip specifically designed for the protocol you are trying to use.
Jeff L.
06-19-2012 10:06 AM
Jeff
Thanks for your prompt response to confirm my conclusions. Our team is now working to change the interface to one compatible with the card.
Mike
