11-09-2015 07:48 PM
I have a custom interface board that connects directly to the front of the PXI-2530 switch matrix card. Is there a document that shows the signal names on each of the pins so that I can compare it to the new 2530B card signals and lay out a new interface board for it?
11-09-2015 07:52 PM
The only thing that changed was a more robust connector. The pinout is still the same.
11-09-2015 08:02 PM
It changed from a 176-pin connector to a 160-pin connector and we were using pins 161 through 167, so I know it can't be a pin for pin replacement. The manuals I found just show the connector without the signal names.
11-09-2015 08:10 PM
Sorry. I was thinking about the PXI-2532B. I know from experience the story behind that one.
