04-19-2006 12:55 PM
04-20-2006 04:47 PM
Hi Putnam,
The reason you may not be seeing Real-Time 7.1.1 as available to install is because the target software for the PXI-8196 is not installed with the LabVIEW Real-Time 7.1 Module. This is because the controller was released after the LabVIEW Real-Time Module was released. As a result, the LabVIEW RT software will show up as "Not Present" on the local host in MAX until the target software is installed on the host PC.
The LabVIEW Real-Time Target software is available on a CD and the current version should allow you to install support for LabVIEW RT 7.1, independent of the LabVIEW Real-Time Module. The files included on the software CD include the LabVIEW Real-Time run-time engine and necessary support files for each LabVIEW Real-Time target.
Install the software from the LabVIEW Real-Time Embedded Software CD onto the host PC. You should then see that LabVIEW RT is installed on the local host.
Hope that helps,
Steven B.
04-24-2006 06:15 PM
