07-17-2006 08:12 AM
07-18-2006 02:11 AM
Are you using DIO lines onboard 4351 for switching on/off heater??
If u are, just acquire value, use a 'in range?' function from comparisons tools>.functions palette for checking for hi gh and low limit.
Connect the boolean output of this function to a case structure and perform high/Low Digital output on DIO lines inside appropriate case.
Hope this helps
regards
Dev
07-18-2006 07:18 AM
07-19-2006 01:19 AM
Yes my suggestion is use the same programming logic I have explained in previous post.
Just put the code for switching on/of relays on PXI 2565 inside the appropriate case
