I wish to do multirecord acquisition with my pxi 6561. I have the following script in mind:
script
generate command 1
generate command 2
generate command 3 marker0 (0)
repeat 99
wait until scripttrigger0
wait until scripttrigger1
generate command 2
generate command 3 marker1 (0)
end repeat
end script
Marker event 0 will be exported to pfi 1 and then will be received on pfi 2 to start a dynamic acquisition session.
Marker event 1 will be exported to pfi 3 and then will be received on pfi 3 to advance to another record in the dynamic acquisition session.
No reference triggers are used, and the minimum number of prereference triggers is 0, so the records will just end when the specified number of samples is acquired.
The number of records will be 100, and the size predetermined to be about 10,000 samples. I will fetch continously, by fetching the backlog and then feeding the number of samples from fetch backlog into the number of samples to fetch. When number in fetch backlog goes over say 14 Msamples, I will output a software trigger to stop dynamic generation which is scripttrigger 0.
The problem now is that I have no line to output a ready to advance trigger since all the trigger lines are used up. I wish to send out an ready to advance trigger to and to reeive this to for scripttrigger1.
The basic idea is to do multirecord acquisiton. I will send out a command sequence given by command 2 and command 3. When command 3 is outputted, I then wish to start acquiring data for 10,000 samples. This is caused by marker event 0 or 1. When the acquisiton of 10,000 samples finishes it will send out a ready to advance event when there is more records to acquire.
In parallel, I will be fetching and writing to the harddisk as fast as possible, by reading the fetch backlog and fetching the number of samples specified in fetch backlog. When fetch backlog goes over 14 Msamples, I wish to pause acquiring and generating data. I will pause generating data by sending a software trigger at scripttrigger0. When this trigger is sent, no more data is generated, and no advance trigger will be outputted since the marker event 1 will not be outputted, so there will be no data acquired as well. The dynamic acquisiton session will be stuck in a ready to advance state. The problem is to now find a place to route the ready to advance trigger and read it but there are no more trigger lines left.
One idea I had, but I don't know if it is possible, is to send out the marker event 0 on pfi 1 and send out marker event on pfi 1 as well since they will not occur simultaneously during the same clock cycle. I would then read th start acquisition event and the advance event on pfi 2 as well, there by leaving pfi 3 and pfi 0 open. I could then send out the ready to advance event on pfi 3 and read it on pfi 1 or maybe do this on pfi 1 and pfi 2 as well.
Please provide any suggestions you may have.
Thank you,
-Tim
