06-14-2012 02:13 PM
We are using a Tektronix VXI1410 Intelliframe with two interfaces to an older PC: GPIB and VXI-MXI. The MXI bus is used in place of the MXI for some faster communications (motor control). Would a newer NI VXI-USB card for the VXI serve the same purpose as the old MXI bus interface to the PC if we upgrade the computer to something more modern?
06-15-2012 01:52 PM - edited 06-15-2012 01:52 PM
Hi LarryPutman,
The VXI -USB card uses USB 2.0 and will allow "32 MB/s sustained throughput across USB and VXI". VXI-MXI 2 has a max throughput of 38 MB/s (I could not find the throughput of VXI-MXI). If your older PC has USB 2.0 ports, I think you would be just fine using the USB card.
