06-06-2014 07:23 AM
I'm using PXI board in Labview FPGA. I'm a new user.
When I'm compiling even a simple program on FPGA target, it is showing error message that compilation failed as clock timing exceeds it. I made sure that it is a simple program only. But it is again encountered.
Any help on this would be appreciated.
Thank you in advance.
06-06-2014 07:47 AM
Can you share any code that is showing this issue?
06-06-2014 11:15 AM
Earlier when i tried with a pulse generation it encountered this pblm. So I tried with a basic labview program.
It encounters the same pblm saying that timing exceeds the limit.
12-03-2014 09:36 AM
Could you please share the code? We can take a look at it for you.
Aditya
