03-27-2008 09:44 AM
03-31-2008 03:46 AM
bump
sorry need an answer on this one
03-31-2008 04:09 AM
Hi slugger,
can you see your 8231 card in MAX? Did you install the driver for it?
Mike
03-31-2008 04:21 AM
nope i cant see it in max
and i believe that it was just put in the rack and no drivers added.
thats not good is it.
at the same time this was done all the pxi cards were moved around the rack and max has never been quite right since then.
reinstall max and start from scratch etc?
ps
when i powered up after the cards had been moved around i had the new hardware detected setups. would this not have re set up all the hardware properly?
many thanks
03-31-2008 06:10 AM
Hi slugger,
normally you install first the driver or the hardware and add then your card. I think you should try this way.
Mike
03-31-2008 07:24 AM
hmmmm
totally removed the 8231 ethernet card and i still cant "see" the ethernet interface in the 8196 controller.
device manager also lists no network adapter present.
06-12-2008 03:34 AM - edited 06-12-2008 03:35 AM
Could you try this under a different slot to see if the system can see it?
06-12-2008 04:04 AM
sorted
was caused by Kontron CP332 graphics card.
when fitted in slot 9 it "stole" the ethernet resources.
moved next to controller and all fine
