10-25-2005 01:07 PM
10-26-2005 02:07 PM
10-27-2005 08:54 AM
10-28-2005 06:51 PM
Hi Jbrib,
The IP-address that you specify whenever you use DataSocket is the one from the
machine that the DataSocket Server is running on. That means that both the
reader and writer have to use the exact same URL to point at the same data
item. One tip: If your VI is on the same machine as the DataSocket Server you
can use the name "localhost" instead of the actual IP-address to
point at the machine.
You can check how many connections have been established to the DataSocket
Server by opening the Servers front panel. You should see the numbers of
connections rise to 2 when both
If it still doesn't work, please connect a Simple Error Handler.vi to the error
output of the DataSocket Read and Write to check for the reason that you can't
connect. Let me know what error you are receiving.
