10-28-2005 04:09 PM
10-31-2005 06:40 PM
Greetings!
Listed below are some suggestions of the issue you might be
facing. Hope you are using LabVIEW RT 7.1 or later.
1) Setting YouOnlyLiveTwice = FALSE in the startup disables the target from
going in to safe mode
2) Also you might want to check if there is a vi that is running on start up
already on your target that is starting every time to reconnect.
3) Do you get a window that pops up stating there is a vi that is running
4) Launch the max ftp client and make sure you remove all the vi's in the
startup folder
5) Are you able to reproduce the issue every time you try targeting the vi to
the target
6) Try rebooting the target controller
Please let me know if this helps
Good Luck
Avi Harjani
11-01-2005 03:34 PM
