06-24-2008 04:56 AM
06-25-2008 04:20 AM
There are a few things that may be causing this to not pick up, firstly does the PXI by default have a Static IP address associated with it? If so you will have to be within the same subnet and IP address range. Secondly are you connecting directly or through a switch, if it's direct please ensure you have a crossover cable or your PC can auto switch to crossover state.
If these are all correct then try rebooting the PXI with the PC plugged into it (ensuring the PC is set to find its IP address via DHCP) and see if MAX can then discover it.
All the best,
06-25-2008 04:43 AM
Rob thanks for your reply.
My issue is the following i have only one network port. If i plug the PXI controller in to this and reboot an IP address is asigned, if i then disconnect from the network and connect to my PC then MAX can pick it up, however if i restart or reboot the controller in this mode the IP address is not stored.
My real problem is that the controller will be operated remotely with a laptop and no access to any network, for controller or laptop, so i need the PC and the controller to be able to link up without any network present, can this be done?
06-25-2008 04:53 AM
06-25-2008 04:56 AM
06-25-2008 05:08 AM
