02-16-2015 07:35 AM
02-16-2015 08:14 AM
When dealing with that much data, I typically just stream the data to a file and then post process as needed. You are also likely getting into memory issues with your queue setup. Can you post your code? There are likely optimizations we can make to get you where you want.
03-03-2015 08:20 PM
i want to press the "store"button as needed and then store one record into a file.a record includes 20M samples.that's all.
