11-05-2006 02:34 PM
11-05-2006 10:53 PM
I assume that you have installed the traditional DAQ legacy Device drivers 7.4.1 that you will find here
Now the device will show up in 'Tradional DAQ devices' folder in Devices and Interfaces section.
In Data Neighborhood, you can create/configure a Virtual channel and use it in your LabVIEW Traditional DAQ>>AI Read function
Or You could use tha AI config function to configure a channel on the VI directly.
Also look at Traditional DAQ example VI's that are shipped with your LabVIEW.
Any doubts, do ask
Dev
11-06-2006 09:33 AM
Hi Jarvie-
In addition to Dev's post, you should be sure that you install Traditional (Legacy) NI-DAQ 7.4.2 from the LabVIEW driver CD. Traditional NI-DAQ 7.4.1 will not support LabVIEW 8.2.
Hopefully this helps-
11-07-2006 02:14 AM
Tom,
Why is Traditional (Legacy) NI-DAQ 7.4.2 not availible on Drivers and Updates page??
here is what a search yields
Dev
11-07-2006 08:04 AM
