10-02-2008 03:30 PM
10-03-2008 03:57 PM
There is not a way to add extra USB ports to a PXI-8176 without using a hub. The only option you have is to try and find a third-party PXI module that has USB ports. I've looked online and all I can find is a third-party PXI controller with 6 USB ports. It is called the "Cool One" by General Micro Systems INC.
Thank you
10-13-2008 10:08 AM
As PXI is built upon the CompactPCI standard, you can use compactPCI boards in a PXI chassis.
A quick google search of "compact pci usb" yielded the following:
