08-16-2005 10:54 AM
08-17-2005 11:27 AM
08-17-2005 04:03 PM
08-18-2005 08:53 AM
02-07-2007 12:34 PM
02-08-2007 02:36 PM
02-08-2007 04:52 PM
I finally did get to where I calibrate 6552 cards with CalExec. The equipment listed for 6551 cards is the same. Have you seen the list and priced everyting on it? The cards and cables you need from NI will run you up to $7 or 8k, depending on what you already may have. You do need 2 of the expensive 1193 switches. Other notes:
Good luck. It took me a lot of time and money. You do need all of those cables listed. And the breakout box and switch modules. It turns into quite a bowl of spaghetti. But when it is all hooked up you can do the cal in 5 or 10 minutes. Let us know how you do.
Tom Morgan
