NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
PXI
Reply
Active Participant
jyang72211
VISA Server and PXI FPGA
I have a PXI-1042 with two PXI-7833R FPGA cards.  I wrote some new code for them, but the PXI doesn't have labview on it (only run-time engine), so I want to run my code remotely on my office PC while controling the device through visa server.  On the PXI, I started visa server and allowed all access.  At the beginning, I was able to see the PXI backplane as a device remotely, but I wasn't able to see the two FPGA cards.  After a while, not even the backplane showed up.  Anybody has a soluation for this?  Thanks!
Member
Vimal_F
Re: VISA Server and PXI FPGA
I have a few questions that I'd like you to answer so we can gain a better understanding of your system.
1. Do you have an embedded controller? If so, what is the model number; i.e PXIe-8108?
2. What OS is on this controller? Windows XP? 7? RT?
3. If you do not have a controller, are you connect through a MXI connection? What MXI card do you have?
4. In your current setup, how are you connected to your chassis? Ethernet?
5. Do you see the chassis in MAX on your host PC.
A block diagram would really help us better picture your system.
Thank you,
Vimal F
Active Participant
jyang72211
Thanks for your help, Vimal.  See below for comments.
1. PXI-8105 http://sine.ni.com/nips/cds/view/p/lang/en/nid/202630
2. XP
3. I have a controller in the PXI-1042 chassis.  The controller is PXI-8105.
4. How is what connected to the chassis?  The controller and fpga cards are all inside the chassis.
5. On computer where the device is connected to, I see the chassis, controller, and FPGA cards in MAX.
Setup
Chassis: PXI-1042
Controller: PXI-8105
Cards: PXI-7833R (quantity = 2)
Active Participant
jyang72211
Hi Vimal,
Is there anything else that you need?  Thanks for looking into this.
Member
Paul-B
Hello jyang72211,
Make sure that the National Instruments RIO Server is running on your Windows computer. The RIO server allows other systems to access RIO devices on your local computer through network connections. You can check the status of the service by Control Panel>>Administrative Tools>>Services. With the RIO Server service running on your computer please double check that you have the correct remote access settings configured in Measurement & Automation Explorer. In MAX, go to Tools>>NI-RIO Settings and make sure that you have an "*" checked in the Remote Device Access list. I have included links to some documentation which have more information regarding this issue. Hope this helps!
Remote Application Development for Windows based CompactRIO
http://www.ni.com/white-paper/13050/en
How do I Configure the RIO Server on my 908x cRIO running Windows Embedded Standard 7?
http://digital.ni.com/public.nsf/allkb/E10AEC4FFBB784368625795100790AA4?OpenDocument
Paul-B
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
