09-10-2008 09:24 AM
I am trying to create an XP embedded component to use my MXI-4 card.
The Target Analyzer Probe does identify that the MXI-4 is present on my development machine.
But, when I import the devices.pmq in the component designer, it fails to include the MXI-4 driver.
Component designer throws a warning: "Could not find a driver for MXI-4 Connection Monitor"
Please suggest.
Thanks.
09-11-2008 05:39 AM
The MXI simply uses Windows PCI drivers and so these should just be present in your installation although we do not officially support XP embedded so I don't know if there could be a conflict because of that. You will also need all of the drivers for the cards on your chassis installed on your embedded system.
09-11-2008 10:56 AM
Thanks James.
Can you please tell me the driver components (and dependencies) apart from the .nimxi4.inf file, so that I can create a custom component for it.
Cheers,
Aditya
09-11-2008 10:59 AM
Also, I need to use my VISA based drivers for rest of the modules, if you can also help me with the com,ponents required.
Thanks.
09-12-2008 05:59 AM
Unfortunately I can't as I don't have a MXI kit here. You will have to set it up on a normal XP machine and see what components it uses, and even then we cannot guarantee it will work.
