PXI
Up to which loop rate can PXIe 8820 Real-time controller reach ?
I was using PXIe8820 to do closed-loop control in labview real time. I take the measurement and give a control signal to actuators at each cycle.
But I can't increase the loop rate up to 3kHz. Is this a limitation of the PXIe8820 controller? Or I need to change the configurations at somewhere?
Can anyone help me with this? Thank you!
(3,988 Views)
I used the PXIe 6363 as data acquisition card ana a hardwire-timed single point acquisition method.
I run the closed-loop for 10s evaluation. It's fine with 3kHz but when I use 4kHz, the real evalution time became 20s. It was really out timed.
Can anybody help me with this issue??
(3,967 Views)
