05-22-2008 07:29 AM
05-23-2008 06:25 AM
You can trigger DAQmx acquisitions by using the DAQmx trigger.vi. Configure this polymorphic vi for Start Digital Edge Trigger and specify the source-parameter to PXISlotx/StartTrigger. If you'd like to send the Scope Trigger to a specific line, you can use the niScope Export Signal.vi. If you send it to e.g. PFI0, you have to specify the DAQmx trigger to this source instead.
Hope it helps.
05-26-2008 07:42 AM
Hej Pelle!
The problem is at DAQmx card PXI-6624, where there is a CI Angular Encoder. It runs and gives the angle, but when I include a DAQmx Start Trigger (Digital Edge).vi, there is a Error of Measurements: "Specified property is not supported by the device or is not applicable to the task". This error comes from Property: Start.TrigType.
Same happens when the triggering is exported from niScope Export Signal.vi as you suggested to the DAQmx measurement on PXI-6624.
Is it possible to use triggering from PXI-5105 to PXI-6624 when measuring an analog singal and to get the angular position when this signal level is above a specific level?
I have attached a simple application, with this problem.
Johan
05-28-2008 03:38 AM
