Hi, Everyone!
I'm trying to perform sampling from two boards at the same time. One board is an ordinary PCI-6224 and the other is a PXI-6229 located in our PXI-system. After a lot of trial and error (and some help from these discussion boards) I succeded performing sycnchronized continuous sampling from both boards by using the VI attached. It exports the master clock to a pfi-port and this signal is taken in by the pxi-board through another pfi-port and a physical wire.
Apparently, the VI manages to trigger the pxi-board, but not every time. Looking at an array indicator while running my main program I se that the channels from the pxi-board "drop out" perhaps one in four times. Any idea what cause this behaviour? I'm an amateur in LV and can't figure this out myself.
regards,
Einar
