08-18-2006 02:53 AM - edited 08-18-2006 02:53 AM
Message Edité par Inpriser le 08-18-2006 02:54 AM
08-22-2006 04:05 AM
Inpriser,
You wanted to use the PXI 10MHz clock to synchronize to 6713s using the PXI capabilities. I’m afraid that since the AO series doesn't have a PLL, you won't be able to use the PXI 10 clock.
I made a few search and found this:
“Neither the 6713 nor any of the AO series support PLL synchronization. However, the M-Series does, though in that case you are limited to a smaller number of analog outputs. Regardless, the best option is using an Arb or other card that can use the Star Trigger, or an m-series device with PLL synchronization capabilities.”
For more info’s about how to deal with PXI and PLL, please check this forum:
http://forums.ni.com/ni/board/message?board.id=170&message.id=11986&requireLogin=False
I’m sorry to disappoint you, hoping you’ll manage to deal with that,
08-22-2006 04:50 AM
The NI 6711/6713/673X can use either the internal 20 MHz timebase or a timebase received over the RTSI bus. In addition, if you configure the device to use the internal timebase, which is software-selectable, you can program the device to drive the internal timebase over the RTSI bus to another device that is programmed to receive this timebase signal. This clock source, whether local or from the RTSI bus, is used by the device as the primary frequency source. The default configuration is to use the internal timebase without driving the RTSI bus timebase signal.
