05-15-2015 03:49 PM - edited 05-15-2015 03:50 PM
Hi all,
I recently bought and installed the very beefy PXIe-8135 RT controller into my PXIe-1065 chassis and I am having mixed results with the DisplayPort video output. If I use the supplied DisplayPort to VGA adapter that NI supplies with the controller I have no issues with the video output. If I use a DisplayPort to HDMI adapter that I have (and use an accomanying HDMI cable) I have no issues. However, I also bought a third party DisplayPort to DVI-D integrated cable and I have no video output from the controller with this cable. If I use the cable with my laptop it works fine. Does anyone have any ideas or troubleshooting tips? Is this a driver problem?
Thanks!
05-18-2015 07:30 PM
bartelma,
What OS are you using on your controller? Do you have dual-boot capability?
05-19-2015 07:05 AM
I'm using the PharLap RT OS and since it's the RT version of the controller it is not Windows bootable
05-19-2015 03:51 PM
Do you have the monitor plugged in and connected when you boot the PXI? This seems to be necessary on some of the newer PXI hardware with certain peripherals.
Beyond that, since this is a third-party cable, I'm not sure what other steps we would be able to try.
05-20-2015 07:37 AM
Yea I know what you mean about needing the monitor cable plugged in when the controller is booted, I've run into that as well. So yes I do have it plugged in on boot.
