Check the voltage levels at the monitor socket on the back of the PXI chassis. The pinout is in the PXI documentation. One of the supply levels is most likely out of spec. The fix is to send you chassis to NI for repair. The good news is, if the levels are not too far out of spec, your modules are probably OK.
