07-07-2008 06:14 AM
07-16-2008 09:41 AM
Dear Mr Bomer,
Thank you for your forum post on our website. Which version of NI FGEN are you using? Please find the latest versions under the following link;
http://joule.ni.com/nidu/cds/fn/p/sb/navsRel/lang/en?q=NI-FGEN
the latest driver is compatible with Labview 7.1 and later. Please let me know if this solves your problem.
Martijn
07-18-2008 12:48 AM
07-18-2008 01:32 AM
Dear Mr Bomer,
Bad to hear that it didn't work. You did uninstall the old driver before installing the new one? Can you provide me with the following information?
- which signal generator are you using? Which PXI slot is the module installed (please try another slot)
- please try the FGEN soft pannel without the hardware installed, can you simulate a signal generator?
- are you working with a PX embedded cintroller or a MXI link?
- which operating system are you running?
finally I noticed that a customer with the same problem reinstalled his Labview run time engine, this solved his problem. Please find the runtime engine under the following link; http://joule.ni.com/nidu/cds/fn/p/sn/n14:en,n19:Windows,n23:4.28.5000/lang/en
Please let me know if this works,
Martijn
07-18-2008 08:56 AM
