10-25-2006 07:50 PM
10-31-2006 01:16 PM
12-08-2006 06:59 AM
Hi. Finally the problem has solved. I still don't know the reason for the strange behavior, but I could workaround it. As I told you, I was using three counters on the 6624 to acquire encoders positions, and a fourth counter to generate the appropriate clock signal from the DSA master oversample clock signal. I used counters ctr0, ctr1, ctr2 and ctr3 respectively. To workaround it, I just used any of counters from ctr4 to ctr7 to generate the clock signal, instead of ctr3. Voilá! Works as expected. Seems to be somethig related to the first 4 counters, versus the last 4.
I would appreciate comments from someone at NI about the possible reasons for this phenomena.
Thank you,
Daniel R.
