I am developing around a PXI chassis, and seem to be having intermittent communications with 3 of the PXI modules, and none whatsoever with the 4th. My configuration is as follows:
PXI-1036 driven by benchtop PC with MXI-4 interconnect
Slot 1: PXI-8331 Interface
Slot 2: PXI-4110 DC Power Supply
Slot 3: PXI 6221 Multifunction DAQ
Slot 4: PXI-2501 Switch Module #1
Slot 5: PXI-2501 Switch Module #2
Slot 6 is empty
MAX fails to recognize Switch Module #1. In fact, when SM#1 is in slot #4, the system does not recognize any of the modules, although the chassis itself still pops up as present. When SM#1 is removed, MAX locates the remaining 3 modules.
I also have tried putting SM#1 in slot #6, and the system saw the other 3 modules, but not SM#1. (I only tries this configuration once).
I have attempted removing the /data file (as suggested in another post), and have removed reinstalled DAQ-MX (version 8.1), along with NI-POWER and NI_SWITCH.
I have now spent about a day swapping modules around, rebooting my chassis/PC over and over, installing software, etc. Any and all help would be appreciated.
