01-26-2016 04:12 AM
Hi all.
I'd like to use a PXIe-6556 card with a SHC68-C68-D4 cable and I'd like to confirm the pinning on my board.
Do I have to use the same pinning than PXIe-6556 (probably not) or do I have to use a mirrored pinning (in 1 becomes pin 34).
Moreover, Ni propose only the footprint for the through connector (R-HS-008068-1B). Any issue if I use the SMD one (R-HS-008068-3) ?
Thank you.
G.
01-27-2016 05:35 AM
Hi Gzmeuh,
The PXIe-6556 card is fully compatible with a SHC68-C68-D4.
Are you building your own cable?
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
