Hi, I have the following setup. PXI 1002 chasis PXI 8175 controller PXI 6025E DAQ card PXI 5152 scope PXI 6602 counter timer. Currently I am not using RealTime.
I have written a program that uses the counter timer for triggering an
external circuit board and the scope for data acquisition. I need to
run the vi on my laptop and get access to the PXI devices.
I
have connected the Laptop to the PXI using a cross over LAN cable and
configured manual IP addresses and identical subnet masks on both
systems. If i run the Remote Device Access Server(RDA) on the PXI
chasis, I can access the 6025E card and a portion of the 6602 card
also. I can see them from MAX directly.But how can I access the scope,
as the RDA server works only with DAQ devices. I tried creating a new remote system.from MAX...but it is showing an error "unable to communicate with remote system"
What I want is
a method to configure the PXI system as a remote device on my Laptop.so
that I can see the PXI cards in NI MAX on my laptop.
I would like to see if I can do this without having to get a new express card.
Please help!! I am newbie with remote systems. Thanks in advance!!
