I am trying to connect my WindowsXP PC to a PXI chassis. The PXI system is a 1011 chassis with a PXI-8175 Controller. It has the PXI-6704 and PXI-6040E boards in it. The SCXI power is switched off. On start up, the PXI starts NI-Serial v2.5 for LabVIEW RT, and successfully starts the NI-VISA Server.
The PC is running WindowsXP SP2. I have LabVIEW 7.1 with FPGA, RT, and RIO recently installed. The DAQ drivers have also been recently reinstalled from the website. There is a working PCI-MOI-16E-1 card installed. Both machines are on the same network.
When starting MAX and expanding Remote Systems the identifier for the PXI system shows up. It shows the correct IP address, and says Connected-Running. I can expand the identifier to show Data Neighboorhood, Devices and Interfaces, Scales, and Software. However, when trying to expand any of these categories, they all show up blank. I have attempted to install software by selecting the Software category and clicking "Install Software" but I get an error that says "The operation could not be completed. Operation failed with error code: 1 Operation Failed."
I believe that I should at least be able to see the PXI controller in the Devices and Interfaces category and from there be able to install or configure the boards that are in the PXI chassis. What else must I do to install this Remote PXI system?
