06-25-2008 04:00 PM
06-26-2008 05:55 PM
Hi Rick,
PXI-6602 calibration requires a 10 MHz, 5 MHz, or 1 MHz clock source that is accurate to within 1 ppm. This clock can be provided by the PXI-6608. The 6608 has a 10 MHz clock that is accurate to 0.075 ppm over 1 year. This information can be found on page 2 of the 6601/6602 Calibration Procedure.
Since the 6608 has such an accurate clock it requires an even more accurate source to calibrate it. 6608 calibration requires a 10 MHz source that is accurate to 0.75 part-per-billion (ppb). We recommend using a rubidium frequency standard clock source. However any 10 MHz clock source that meets the 0.75 ppb spec can be used. This information can be found on page 2 of the NI 6608 Timing I/O Device Calibration Procedure.
Please let me know if you have any questions and take care.
Thanks,06-27-2008 08:32 AM
