06-04-2008 01:35 PM
06-05-2008 03:16 PM
06-05-2008 03:21 PM
06-09-2008 12:10 AM
I recommend checking the following
1) The PXI system is identified in MAX
2) The right terminal block to the 1520 is set correctly in MAX
3)What you are having is a different issue , but it is worth checking the following link.:
http://digital.ni.com/public.nsf/allkb/C56F7D3E11C546208625726100672CA2?OpenDocument
4) Check chapter two the 1520 manual, and check the right connection as well as what bridge configuration you are using.
5) If available try measuring the voltage output from the load cell with a different device ( a separate multimeter), and see if the load cell is operating as it should be.
6) Set the acquisition mode in the task you create in MAX to continous.
best of luck
