NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
PXI
Reply
Member
Bramatti
Problems in configuration of two SCXI-1141 filters (in parallel mode) in a PXI-1010 with a 6031E DAQ and SXCI-1353 kit
I am trying to configure two SCXI-1141 filters in parallel mode in a 6031E DAQ in a PXI-1010 using SCXI-1353 kit (double shielded cable and two conectors) at rear of two SCX!-1141. I am using also a ICP SCXI-1531 in mode multiplex. I tried many configurations, but I can control only one of the SCXI-1141 boards. The second I can't set the filter. Sometimes it function, but when I boot the PXI, the filter dont function more, only the first. Does anyone know a correct configuration? Is it possible?
Bramatti
Member
Geneva L.
Re: Problems in configuration of two SCXI-1141 filters (in parallel mode) in a PXI-1010 with a 6031E DAQ and SXCI-1353 kit
Bramatti,
I'm not quite clear on how your system is set up. Do you have two PXI-6031E boards each connected via the SCXI-1353 MIO-16 connector end cabled to the SCXI-1141? Note that the SCXI-1353 has the two connector ends--MIO-16 and Extended I/O. As you can see in the SCXI-1353 Cable Installation Guide, with your particular board, the Extended I/O end can only connect to the SCXI-1180 feedthrough panel.
The SCXI-1531 has onboard filters, so it doesn't sound like you are trying to cascade any of these modules. Is the SCXI-1531 connected to another board? Since it is a simultaneous sampling board, in a multiplexed SCXI system, it would be cabled directly to a DAQ board.
You can find more information about configuration at the http://www.ni.com/support/scxi pages.
Also, the Getting Started with SCXI manual is a vital reference. This and the 1353 Guide are also available at the http://www.ni.com/support pages.
Geneva L.
http://www.ni.com/ask
Member
Bramatti
Geneva
I have 03 DAQ boards in my PXI-1010.
1) PXI slot 4 - SXCI-6031E connected in parallel mode with two SCXI-1141 filters boards (Chassis slots 2 and 3) , via SCXI-1353 shielded cable kit, using two parts of the double cable)
2) PXI slot 6 - SCXI 6031E connected in parallel mode with one SCXI-1141 filters boards (Chassis slot 4) , via SCXI-1353 shielded cable kit (using one part of the double cable).
3) PXI slot 8 - SCXI-6030E connected with a SCXI-1531 ICP board (Chassis slot 1) in mode multiplex.
I am trying control the filter in chassis slot 3, but only the filters in slot 2 and 4 function. In the configuration, only the filter in slot 2 "see" the 6031E in PXI slot 4. The filter in slot 3 does not see the daq Board - "none".
Is it possible
to make this configuration? Do you know the right way?
Bramatti
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
