Looking over the spec sheet page 23, it seems like the PXI module provides the power so no external supply is needed.
It should be possible to measure 5V @ 40mA. As to the maximum, this board is able to produce a maximum of 60V @ 150mA to drive a relay so I would guess that it is also able to sample your 5V @ 150mA. Use that 150mA as a limit on the current you feed. It could also be a possibility that this board has internal circuitiry to protect itself from excess current.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
