06-17-2016 12:45 AM - edited 06-17-2016 12:48 AM
Solved! Go to Solution.
06-20-2016 05:37 AM
Hi Arjun,
I went through the Snippets you provided. After creating the P2P stream you need to enable it also. It would be best if you can go through the shipped examples in the LabVIEW for P2P streaming. Please refer to the Snippet I attached of the vi and also the example that is shipped with LabVIEW. You can directly use the project by changing the FPGA Target to that of yours and use.
Hope this helps
06-20-2016 11:27 PM
Thank you Yaskadeva. That code works. I did not know about example finder too.
Regards
Arjun Nadh
