PXI
PXImc
Hello
I would use PXImc between two system, a PXI used for HIL simulation with veristand installed and a ETS RT target used for the test bench control.
The test bench controller acquires data, closes loop controll with PID and generates command to servovalvs; now I want to share data from the controller to the HIL system and from HIL system to the controller. On the controller I have my realtime software,Veristand isn't installed, how can I do?
On HIL system I have to configure custom device PXImc and on controller I have to use PXImc labview function?
How can I synchronize the two systems? Can I use PXImc interrupts?
Thanks in advance
Ezio
(5,146 Views)
Hi Ezio,
attached the link to custom device for PXImc:
https://decibel.ni.com/content/docs/DOC-34816
I think can you find a very helpful info about your problem.
Best Regards
Mario
(5,125 Views)
Thankyou Mario
I already installed custom device in my Veristand but I want to understand if it could be a problem the fact  that on my Controller (the machine that controls the test bench ) I haven't got veristand. The simulation system on PXI with veristand doesn't see the Controller machine.
Have you got some experience with PXImc?
Ezio
(5,109 Views)
