I would use PXImc between two system, a PXI used for HIL simulation with veristand installed and a ETS RT target used for the test bench control. The test bench controller acquires data, closes loop controll with PID and generates command to servovalvs; now I want to share data from the controller to the HIL system and from HIL system to the controller. On the controller I have my realtime software,Veristand isn't installed, how can I do? On HIL system I have to configure custom device PXImc and on controller I have to use PXImc labview function? How can I synchronize the two systems? Can I use PXImc interrupts? Thanks in advance Ezio
Thankyou Mario I already installed custom device in my Veristand but I want to understand if it could be a problem the fact that on my Controller (the machine that controls the test bench ) I haven't got veristand. The simulation system on PXI with veristand doesn't see the Controller machine. Have you got some experience with PXImc? Ezio
